Making a 52mm spindle mount
A project log for OX CNC
OX CNC from OpenBuilds
charliexcharliex • 07/19/2015 at 23:18•0 Comments
Spindle mount i made for the OX cnc with a band saw, drill press and a bi-metal wood hole saw ( even thought it claims to cut metal ok) 2" hole saw is 51mm , motor is 52mm so it is fine.
3d printed out of PLA
giant teeth !
no pics of the bandsawing, since i was bandsawing and can't run the camera at the same time ;)
rear plate , fuzzy! drilled it out on the drill press again.
came out ok, temporary wiring since i'm swapping out the speed controller and seeing how it all goes.
so we're ready to make our first 'chips/cuts'
