First tests with my controller board ATMEGA 32, 8Mhz LTC2756 18Bit DAC
Made some changes in the coding.
MAXVALUE=262144
A_Rate = 1000
D_Rate = 500
S_Level= 131072
R_Rate = 250
Update Rate: 1ms
Oscilloscope Setting: 200ms/cm
MAXVALUE=262144
A_Rate = 10000
D_Rate = 500
S_Level= 131072
R_Rate = 250
Update Rate: 1ms
Oscilloscope Setting: 50ms/cm
MAXVALUE=262144
A_Rate = 100000
D_Rate = 500
S_Level= 131072
R_Rate = 250
Update Rate: 1ms
Oscilloscope Setting: 1ms/cm
