We want to pick you up right where you are, and that's probably in some cozy arduino environment. Or in your garden (this seems to be a popular place in this year's prize). Let's take a piece of Verilog and compile it into a binary!
After you started iCECube2 you should see a simple main window with menus, a project property tree and an inactive editor area:
In the project tree, double-click "New Project". The project and device setup dialog appears:
- Select a directory for your new project and give it a name.
- Select the correct device: the dipsy's FPGA is an iCE40UL, 1K, in an SWG16 package.
- Select 3.3V for the I/O banks.
The project wizard now asks for "Files to add" - we can now add HDL files, both VHDL and Verilog are ok. One quirk is that we can't create new files in this dialog, so we have to create a new file externally. Open your favourite editor and add the following magic:
module top ( // input: // outputs: ledout ); output ledout; wire hfosc_clk; wire led; wire ledout; SB_HFOSC OSCInst0 ( .CLKHFEN(1'b1), .CLKHFPU(1'b1), .CLKHF(hfosc_clk) ) /* synthesis ROUTE_THROUGH_FABRIC= [0] */; // don't know the implications of this, sorry defparam OSCInst0.CLKHF_DIV = "0b00"; // divide by 1; 48 MHz output SB_RGBA_DRV RGBA_DRIVER ( .CURREN(1'b1), .RGBLEDEN(1'b1), .RGB0PWM(led), .RGB1PWM(1'b0), .RGB2PWM(1'b0), .RGB0(ledout) ); defparam RGBA_DRIVER.CURRENT_MODE = "0b0"; defparam RGBA_DRIVER.RGB0_CURRENT = "0b1"; defparam RGBA_DRIVER.RGB1_CURRENT = "0b1"; defparam RGBA_DRIVER.RGB2_CURRENT = "0b1"; reg[31:0] cnt = 0; reg[31:0] factor = 48000000; // divide clock down to 1 Hz reg divout = 1'b0; assign led = divout; always @(posedge hfosc_clk) begin if(factor != 0) cnt = cnt + 1; if (cnt == factor) begin cnt = 0; divout = ~divout; end end endmoduleSave the file wherever you want to, but please pick a place you can find again!
Add the file to you project:
make sure to not only select your files, but to move them into the right part of the window by double-clicking the file or by selecting it/them and clicking ">>". Click "Finish".
Before we can synthesize out design we need to pick the correct synthesis tool. Right-click the respective tree item:
Select "Lattice LSE" in the dialog that pops up.
Now, to synthesize, go to Tool -> Run All. If everything is fine, iCEcube2 will do all synthesis, place & route or whatever else is needed (I have no clue, to be honest) and give you a binary file that you can use to configure a dipsy.
