SMD soldering to the extreme? Well this is how the first DIPSY boards for HaD Prize did got soldered per hand.
to be added here - bga soldering the easy part..
Boards ready to assemble the small parts
bit of solder added for the R and C that come on this side of the PCB
0402 Resistors soldered, they are lower than 0402 C, so bit easier
now the 0402 caps are soldered too from one side
both R and C are soldered, time to turn the PCB over
same story repeating, 0402 caps are soldered form one side first, for the SOT23-3 in pad has bit of solder on it
done all SMD parts are soldered
Preparing for through hole soldering, it is important to push the pins into the socket below, or they would be misaligned.
and done
So what went WRONG ???
ANSWER, out of 4 assembled, one DIPSY got the pins inserted upside down. So the through hole soldering yield was 75%
Antti Lukats
The joys of manual assembly without a physical foolproof mark :-D
