A completed chassis
A project log for Reprap Busby
What's the future of 3D printing technology? Wearables. Therefore, a wearable 3D printer.
benchoffBenchoff • 09/11/2015 at 17:22•1 Comment
Finally, after about two kg of filament (mostly failed prints), the chassis is done. From now on, it's an integration task - installing motors and wiring electronics. The body is done.
Shot of the competed printer with a can of coke inside. Yep, it's small. Here's a comparison shot with a Makerbot Thing-O-Matic:
How about a comparison between machine size and build volume? The Thing-O-Matic is 300 x 300 x 400 mm, with a build volume of 100mm^3. The ratio of build volume to machine size for the Takerbot is 1:36.
My machine is 150mm^3, and I should have a build volume of 45mm^3. That's close to a ratio of 1:27. My machine has a larger build volume to machine size than a thing-o-matic. Of course that's a terrible metric, but it is a statistic I will be using for the inevitable million dollar kickstarter.
ajlitt wrote 09/12/2015 at 16:12 • point
i dig the Tantillus style can for scale
