[Matt] didn't liked long links. He experimented to see what is really needed, and found out you can drop the name-title part. Keep only the ID number.
So always use
https://hackaday.io/project/4731/log/20286
instead of
https://hackaday.io/project/4731-esplux-smarts-for-your-downlights/log/20286-scope-results
More then that, [Matt] found out that the text doesn't really matter at all:
https://hackaday.io/project/4731-you-can-write-here-whatever-you-want/log/20286-hack-a-day-will-look-at-the-numbers-only
Many of the links provided by the site itself, such as those to related projects and those to log entries from the feed, use the ID numbers only.
