This is just to alleviate the guilt for skulling yourself.
:o)
How to follow yourself
- Hover the mouse over your profile icon and remember your ID number
- Go to your profile page (e.g. by clicking on your profile icon)
- Similar with the previous log entry, where you gave yourself a Skull, type the following in your browser's Address Bar:
JavaScript:$.ajax({url : "/hacker/10287/follow", method : "POST", timeout : 15e3, data : {_csrf : csrftoken}})
Note: Some browsers use to mangle the word "JavaScript:" from the Address Bar. If you use copy/paste, before pressing Enter, check that the first word in the Address Bar is indeed "JavaScript:". If not, add it manually, so the text in the Address Bar will be the same as in the example. You may want to change the profile ID with your own profile number.
