BT LE changed to connector for WiFI
A project log for Arduino Compatible Zynq Shield
Xilinx Zynq SoC, Arduino Compatible, 2x ARM Cortex A9, LPDDR2 Memory, USB OTG, on-board USB JTAG and UART.
antti-lukatsAntti Lukats 07/06/2015 at 11:200 Comments
Last minute change the BT LE IC is going off the board, and will be replaced with 8 pin socket ready for the ESP8266 module.
