Bus viewer with LEDs
A project log for AYTABTU - Discrete Computer
After the apocalypse we have to build computers from stuff we can make at home, I.E Transistors, diodes and resistors.
matsengmatseng 07/16/2015 at 07:450 Comments
Ah yes.... I also did a small board with eight buffered LEDs . The inputs are connected via a 680K resistor (to load the DUT as little as possible) and and diode to level-shift the active level up a bit.
The gain of the 2n3904's is enough to drive LEDs decently bright with the minuscule current that passes thru the 680K resistor at 5 volts (minus the diode and transistor junction drops).
Rich text editor
