K-9's drive system uses two Razor scooter motors from an E100 model. The drive system is modular at the moment allowing me to remove the motor and wheels as a packet. I'm designing a new drive cradle out of aluminum which will have these drive motors and wheels built in. This will lower the weight of the entire bot and increase the run time.
