I thought I had learned my lesson with the first museum exhibit I developed; don't use buttons because people, especially children, are brutal. So I moved to capacitive touch buttons. And I thought that would solve the problem. A single sheet of acrylic in front of each column of elements would be easy to clean, would provide a nice interface, and wouldn't have any mechanical problems. Well, it does all those things, but presented me with a billion other problems.
I need help figuring out how to get the cap touch to work for the elements. Here's how it's configured now:
- 1/8" acrylic sheet on the full column of elements.
- Photo glossy sheet of paper with the element description and a 'button' that says "Press to Start"
- 1/8" acrylic piece behind the sheet of paper to hold it.
- 3"x1.5" piece of copper tape attached to the back of the acrylic. If you're keeping track, that's 1/4" of acrylic and a glossy sheet of paper between the finger and the foil.
- 4" wire from the foil to the pin.
- 10M Ohm resistor between the two pins on the ATTiny (using the capsense library).
- 22pF capacitor between the sense pin and ground.
- A custom library abstracts away the capsense library so every element gets the same configuration for touch sensitivity.
- There is a ground plane on the PCB, and every element has a cable carrying +5V, +12V, and ground back to an ATX power supply which is connected via a 3 prong power cable into a power strip.
- Acrylic wiped down with anti-static, anti-fog wipe.
- All elements run for a certain amount of time and then stop. During that time they ignore the button. When they stop running, they start looking at the button again for input.
- The cap sense library allows recalibration every N seconds. I have this set to 20.
This works. Usually. It worked in testing just fine. However, when I installed everything at the museum, things went crazy. Here are some of the problems:
- One of the columns is sensitive in such a way that touching anywhere on the acrylic sheet will activate the whole column.
- Some of the elements will activate way too easily.
- Others require a full palm.
- Sometimes they just start on their own.
- Sometimes you can activate them and they'll start, but even if you're standing a few feet away they'll keep going a few more times before they finally stop.
I spent a lot of time playing around with different sensitivity values for this, but I'm worried that it doesn't matter because each element seems to behave differently. I'd really like a consistent configuration because putting them in and taking them out of the installation is difficult, so tweaking each element would be horrible.
Bob Baddeley
This comment may be far too late to help, but something I've considered for a touchless sensor in the past has been an IR distance sensor. If the acrylic isn't too opaque or foggy in the IR spectrum, it might be a more reliable choice. (i.e. something like: https://www.sparkfun.com/products/242). Instead of instructions to "touch the button..." you'd have to say something like "wave your hand here..."
