Finaly i took the time to integrate the Copter Module with the Copter.
It is a bit "tight fit" the Landing gear is restricting a easy slide in and out... and the PCB gets loose to easy.. at least it is bound to the LiPo-Akku.
Overall I'm still statisfied with the outcome :)
Next idea is to allow tethered Flying ^^
