Warning etc etc, use with caution... Might contain bugs :)
#!/usr/bin/python3.5
import sys
if len(sys.argv) <2:
print( "usage:" )
print(" " + sys.argv[0] + " [.PCK file]", "[Folder-prefix]" )
print( " " )
exit()
import os
from binascii import crc32
from struct import unpack
#get unpack file
src_file_path = sys.argv[1]
#read file length
src_file_size = os.path.getsize(src_file_path)
#read file
b = bytearray(open(src_file_path, 'rb').read())
# crude bytearray to String converter
def toStr(b):
return "".join(["%c"%i for i in b]).strip("\x00")
# convert 4 bytes to int
def word2int(w):
return unpack("<I", w)[0]
# crude filetable parser
def getHeader(b, datastart):
beginstart=b.find(63) #"?"
filename = toStr(b[0:beginstart]).replace("\\","/")
beginstart+=1
beginlength=b.find(63,beginstart) #"?"
start = int(b[beginstart:beginlength],16) + datastart + 4
beginlength+=1
length = int(b[beginlength:beginlength+10],16)
return {
"filename": filename,
"start" : start,
"length" : length,
#crude way to create nonexisting directories
def checkCreateDir(filename):
if not os.path.exists(os.path.dirname(filename)):
try:
os.makedirs(os.path.dirname(filename))
except OSError as exc: # Guard against race condition
if exc.errno != errno.EEXIST:
raise
def save(filename, data):
checkCreateDir(prefix + "/" + filename) #create missing directories
print ("writing %s\t (%d bytes)"%(filename,len(data)))
open(prefix + "/" + filename, 'wb').write(data)
## Start decoding
print("Unknown byte 0:\t"+ str(b[0]))
print("Unknown byte 1:\t"+ str(b[1]))
print("Unknown byte 2:\t"+ str(b[2]))
print("Unknown byte 3:\t"+ str(b[3]))
prefix = sys.argv[2] if len(sys.argv)>=3 else "."
headerstart_token = bytearray((int(62), int(0x0d), int(0x0a)))
headerstart = b.find(headerstart_token,0)+3
pos=headerstart
datastart_token = bytearray((int(0x0d), int(0x0a), int(0x0d), int(0x0a)))
datastart = b.find(datastart_token,0)
print("header end: \t"+ str(datastart))
nHeaders = b.count(int(13),4,datastart)
print("# files \t: "+str(nHeaders))
# crude way to parse the directory table
files = []
print ("found %i files\n"%nHeaders)
token = bytearray((int(0x0d), int(0x0a)))
for i in range(nHeaders):
pos2=b.find(token,pos)
h = getHeader(b[pos:pos2], datastart)
files.append(h)
print(h)
pos = int(pos2)+2
for h in files:
bFile = b[h["start"]:h["start"]+h["length"]]
#write stripped file
save(h["filename"],bFile)
print("Done!")
Daniel Wiegert
The unpacker is also here https://github.com/Damme/LandLord/blob/master/unpack_pck.py
But I unpacked fw v2.66 with the code from this page, it works great!
$ python --version
Python 3.7.10
$ db504_v2.66_extracted % python ../../unpacker.py ../db504_v2.66_30-10-2017.pck
Unknown byte 0: 197
Unknown byte 1: 24
Unknown byte 2: 200
Unknown byte 3: 67
header end: 2418
# files : 50
found 50 files
{'filename': 'db504 v2.66 30-10-2017.bin', 'start': 2422, 'length': 363076}
{'filename': 'web_files/debugPage.html', 'start': 365498, 'length': 23187}
{'filename': 'web_files/dummy.html', 'start': 388685, 'length': 2}
{'filename': 'web_files/index.htm', 'start': 388687, 'length': 13929}
{'filename': 'web_files/index.html', 'start': 402616, 'length': 13929}
{'filename': 'web_files/log.html', 'start': 416545, 'length': 4116}
{'filename': 'web_files/manifest.json', 'start': 420661, 'length': 667}
{'filename': 'web_files/css/style.css', 'start': 421328, 'length': 10653}
{'filename': 'web_files/css/styleLog.css', 'start': 431981, 'length': 13279}
{'filename': 'web_files/img/android-icon-1x.png', 'start': 445260, 'length': 1663}
{'filename': 'web_files/img/android-icon-2x.png', 'start': 446923, 'length': 2349}
{'filename': 'web_files/img/android-icon-3x.png', 'start': 449272, 'length': 3098}
{'filename': 'web_files/img/android-icon-4x.png', 'start': 452370, 'length': 4108}
{'filename': 'web_files/img/back-highlight.png', 'start': 456478, 'length': 1344}
{'filename': 'web_files/img/back.png', 'start': 457822, 'length': 1345}
{'filename': 'web_files/img/close.png', 'start': 459167, 'length': 1038}
{'filename': 'web_files/img/ios-icon-58@2x.png', 'start': 460205, 'length': 1661}
{'filename': 'web_files/img/ios-icon-60@2x.png', 'start': 461866, 'length': 2864}
{'filename': 'web_files/img/ios-icon-60@3x.png', 'start': 464730, 'length': 3897}
{'filename': 'web_files/img/ios-icon-76.png', 'start': 468627, 'length': 2097}
{'filename': 'web_files/img/ios-icon-76@2x.png', 'start': 470724, 'length': 17439}
{'filename': 'web_files/img/lock.png', 'start': 488163, 'length': 1321}
{'filename': 'web_files/img/logo.png', 'start': 489484, 'length': 2530}
{'filename': 'web_files/img/menu-highlight.png', 'start': 492014, 'length': 1090}
{'filename': 'web_files/img/menu.png', 'start': 493104, 'length': 1084}
{'filename': 'web_files/img/minus-highlight.png', 'start': 494188, 'length': 1035}
{'filename': 'web_files/img/minus.png', 'start': 495223, 'length': 1041}
{'filename': 'web_files/img/plus-highlight.png', 'start': 496264, 'length': 1150}
{'filename': 'web_files/img/plus.png', 'start': 497414, 'length': 1142}
{'filename': 'web_files/js/app.js.gz', 'start': 498556, 'length': 5517}
{'filename': 'web_files/js/lib.js.gz', 'start': 504073, 'length': 87122}
{'filename': 'web_files/locale/da.js', 'start': 591195, 'length': 3869}
{'filename': 'web_files/locale/de.js', 'start': 595064, 'length': 4019}
{'filename': 'web_files/locale/en.js', 'start': 599083, 'length': 3759}
{'filename': 'web_files/locale/es.js', 'start': 602842, 'length': 4118}
{'filename': 'web_files/locale/fi.js', 'start': 606960, 'length': 4022}
{'filename': 'web_files/locale/fr.js', 'start': 610982, 'length': 4231}
{'filename': 'web_files/locale/it.js', 'start': 615213, 'length': 3870}
{'filename': 'web_files/locale/nb.js', 'start': 619083, 'length': 3777}
{'filename': 'web_files/locale/nl.js', 'start': 622860, 'length': 3854}
{'filename': 'web_files/locale/pt.js', 'start': 626714, 'length': 4101}
{'filename': 'web_files/locale/sv.js', 'start': 630815, 'length': 3870}
{'filename': 'wifi/1iuinst1.bin', 'start': 634685, 'length': 9612}
{'filename': 'wifi/2iuinst2.bin', 'start': 644297, 'length': 4}
{'filename': 'wifi/3iudata.bin', 'start': 644301, 'length': 400}
{'filename': 'wifi/4ffinst1.bin', 'start': 644701, 'length': 65388}
{'filename': 'wifi/5ffinst2.bin', 'start': 710089, 'length': 30128}
{'filename': 'wifi/6ffdata.bin', 'start': 740217, 'length': 58464}
{'filename': 'wifi/wifiFwVersion.txt', 'start': 798681, 'length': 6}
{'filename': 'wire/Boundary 0.7.bin', 'start': 798687, 'length': 229376}
writing db504 v2.66 30-10-2017.bin (363076 bytes)
writing web_files/debugPage.html (23187 bytes)
writing web_files/dummy.html (2 bytes)
writing web_files/index.htm (13929 bytes)
writing web_files/index.html (13929 bytes)
writing web_files/log.html (4116 bytes)
writing web_files/manifest.json (667 bytes)
writing web_files/css/style.css (10653 bytes)
writing web_files/css/styleLog.css (13279 bytes)
writing web_files/img/android-icon-1x.png (1663 bytes)
writing web_files/img/android-icon-2x.png (2349 bytes)
writing web_files/img/android-icon-3x.png (3098 bytes)
writing web_files/img/android-icon-4x.png (4108 bytes)
writing web_files/img/back-highlight.png (1344 bytes)
writing web_files/img/back.png (1345 bytes)
writing web_files/img/close.png (1038 bytes)
writing web_files/img/ios-icon-58@2x.png (1661 bytes)
writing web_files/img/ios-icon-60@2x.png (2864 bytes)
writing web_files/img/ios-icon-60@3x.png (3897 bytes)
writing web_files/img/ios-icon-76.png (2097 bytes)
writing web_files/img/ios-icon-76@2x.png (17439 bytes)
writing web_files/img/lock.png (1321 bytes)
writing web_files/img/logo.png (2530 bytes)
writing web_files/img/menu-highlight.png (1090 bytes)
writing web_files/img/menu.png (1084 bytes)
writing web_files/img/minus-highlight.png (1035 bytes)
writing web_files/img/minus.png (1041 bytes)
writing web_files/img/plus-highlight.png (1150 bytes)
writing web_files/img/plus.png (1142 bytes)
writing web_files/js/app.js.gz (5517 bytes)
writing web_files/js/lib.js.gz (87122 bytes)
writing web_files/locale/da.js (3869 bytes)
writing web_files/locale/de.js (4019 bytes)
writing web_files/locale/en.js (3759 bytes)
writing web_files/locale/es.js (4118 bytes)
writing web_files/locale/fi.js (4022 bytes)
writing web_files/locale/fr.js (4231 bytes)
writing web_files/locale/it.js (3870 bytes)
writing web_files/locale/nb.js (3777 bytes)
writing web_files/locale/nl.js (3854 bytes)
writing web_files/locale/pt.js (4101 bytes)
writing web_files/locale/sv.js (3870 bytes)
writing wifi/1iuinst1.bin (9612 bytes)
writing wifi/2iuinst2.bin (4 bytes)
writing wifi/3iudata.bin (400 bytes)
writing wifi/4ffinst1.bin (65388 bytes)
writing wifi/5ffinst2.bin (30128 bytes)
writing wifi/6ffdata.bin (58464 bytes)
writing wifi/wifiFwVersion.txt (6 bytes)
writing wire/Boundary 0.7.bin (229376 bytes)
Done!
Thanks for this, have extracted db510-v3.26.pck and looked like it went fine:
Unknown byte 0: 242
Unknown byte 1: 202
Unknown byte 2: 19
Unknown byte 3: 105
header end: 234
# files : 4
found 4 files
{'start': 238, 'filename': 'db510 v3.26 22-12-2017.bin', 'length': 195844}
{'start': 196082, 'filename': 'wifi_firmware/wififw v0.12.bin', 'length': 523520}
{'start': 719602, 'filename': 'wire_firmware/Boundary 2.0.bin', 'length': 32768}
{'start': 752370, 'filename': 'wire_firmware/Boundary BL 1.1.bin', 'length': 32768}
writing db510 v3.26 22-12-2017.bin (195844 bytes)
writing wifi_firmware/wififw v0.12.bin (523520 bytes)
writing wire_firmware/Boundary 2.0.bin (32768 bytes)
writing wire_firmware/Boundary BL 1.1.bin (32768 bytes)
So looks good. Is there any way of reversing the .bin or as it's a compiled ARM binary I'm guessing that's a no?
Anywhere have the original source for the stock firmware (Is it under GPL has anyone done an information request from Worx by any chance)?
Hi Daniel,
I've just used your unpacker with the latest Firmware available for my 2017 Worx WR101SI.
It unpacks without problems, but if i scan the binary for strings, there isn't a single one that makes sense as well as no known headers.
Do you know if the kind of obfuscate their binarys?
Hello,
I have tested the script . Here came the following error :
Unknown byte 0: 17
Unknown byte 1: 38
Unknown byte 2: 172
Unknown byte 3: 156
header end: 2418
Traceback (most recent call last):
File "unpack_pck.py", line 61, in
TypeError: Type int doesn't support the buffer API
Greetings
Hmm, I am no python guru, what version do you run? It works in my Python 3.5.2
I just tried python 2 and got same error. This is written for python 3.
