Delayed Forums response is due to a failure for the pics to develop (or get sent to me). Also, coming down with something and had to troubleshoot some problems not associated with Pipboy project.
Here I am with the new MicroSoft authorized GameStop controller cracked open, upside down so the buttons don't fall out.
Here's the next step:
The rumble packs are both sitting off to the side, the only things with wires in the controller. What you see there is my incredibly sexy assistant (part time Lingerie model) Buffy holding the two wires against the RIGHT arrow of the crosspad's connection.
Each of the connection areas for the d-pad / control cross as well as the x,y,a,b buttons are all composed of those silver circles split in half down the middle. When the “button” is pressed in, it closing the contact between the two and while the connection is split on the circuit board the button connection doesn't appear to be split.
Unfortunately the circuit board is replete with circuitry which I must not damage or short when I solder these wires to their respective button connection sites. I must find a way to hold the wire to the board or within the controller so that there is no stress or tension that tugs at the soldered connection while at the same time putting together some sort of safety so that if the controller get's dropped away from the Pipboy the wiring doesn't take the tension or shock.
My idea here is to wrap all the wiring with a cord of shorter length so that the outer cord, just like with store bought electronics, absorbs the shock and tension, leaving the wire inside uninjured. Also, I think having a breakaway connector would be wise as well, so that the controller can be used without the Pipboy attached and so that the Pipboy can be worn (cosplay) without the controller dragging along. This breakaway connection would potentially solve both problems by insuring that a dropped controller doesn't tear out the soldering and allows for cosplay. Not that I cosplay. But who knows? IF I build this maybe some more working parts and voila, costume.
