Stop. Don't.
Bitcraze has open sourced all their hard work, which is what make this project possible. The Crazyradio PA is inexpensive compared to the Crazyflie itself. It's a lot of work to save $30 and end up with no better range than BLE.
So why did you?
I had placed an order for a Crazyflie 2.0 and didn't realize that I should have grabbed a Crazyradio PA at the same time to open up some functionality. I thought it would be a quick hack to turn the receiver into a low power Crazyradio. That way I could play with one before I have a chance to order the real deal.
Hardware
This is the donor mouse. It still works, and at some point I'll replace the receiver. But for now a sacrifice is required.
I cracked open the shell to see if there were any test points exposing the SPI interface and required PROG pin:
A little squeeze from a pair of pliers and the glue holding the cap to the body cracks.
As you can see, no test points, just discretes and the chip. The orange dot is a dead giveaway that part or all of the firmware was programmed before the chip was soldered on the board.
I checked the pinout of the datasheet, and beeped out a few pins. The SPI port, VCC, and ground are all available on the edge of the package facing the camera above, while PROG is on one of the resistors to the bottom left. Fortunately the SPI port pins are unconnected. Unpleasant, but not impossible with some magnet wire.
This went much faster than you might expect. Magnet wire is designed so that solder cooks off the enamel insulation. So by carefully tinning the tip of the wires and using plenty of flux on the PCB, it's easy to solder small targets like QFN feet.
My iron has a 1/16" chisel tip, which is great for cozying up to the tiny exposed QFN pads. To keep from desoldering neighboring wires, I tacked wires down the edge with the SPI port sequentially. With good lighting I didn't need a microscope during soldering, though I used my cheapo USB magnified camera to inspect the work afterwards. I ended up picking off GND from a bypass cap since the ground plane at the QFP lead was too heavy to solder in those close quarters, but everything else was soldered to the QFP.
With all the wires in place I used double stick tape to hold it tight to a breadboard. The tape was unexpectedly helpful in holding the wires as a sort of strain relief. I ran the free ends of the wire perpendicular to pins on a header I put on the board, tacked each lead, and trimmed them.
I then followed the wiki to wire each signal to a pin on a Bus Pirate.
This took about 45 minutes from start to finish for the hardware work.
Software
I started out with the buspirate_nrf24lu1 project on Github. This is the script Bitcraze recommends on their wiki for recovering a Crazyradio with a Bus Pirate. buspirate_nrf24lu1 is a Perl script that works on OSX or Linux (after cpanning Device::SerialPort) to erase the nRF24LU1 and write a binary blob to flash.
Before I cracked apart the dongle, I looked at the GPIO and peripheral requirements for Crazyradio. There are only a few GPIOs on the nRF24LU1+, and Crazyradio only uses two for LEDs (Crazyradio PA uses an extra one for controlling the amp). The dongle uses none of the GPIOs, so it looked like it should work without any changes.
My first attempt at running this seemed to work, but complained about the status register being incorrect (0x24 and not 0x20) before erasing. The datasheet decodes this to WREN and RDISMB set, with WREN being expected (enable writes, since it's about to do an erase) and RDISMB informing that the main flash space readback is disabled. Although this shouldn't hurt Crazyradio, I didn't want to take any chance that could only be fixed by soldering to the SPI port again.
I added commands to erase the infopage, a separate flash space for unique configuration data. The field that locks reads and writes to certain memory spaces lives here. That seemed to fix the error message, and the flash of the firmware binary in the repo completed after 5 minutes.
Hmm.
I desoldered the wires, put the board back in the case, plugged it in, and it enumerated as a Crazyradio, though running an older version of the firmware (0.51). I downloaded the DFU tool from Bitcraze's github, pointed it at the latest binary... and it hung waiting for the bootloader.
I did some searching, and it seems others trying this utility have run into this problem. The binary in that repo is just the Crazyradio firmware and doesn't include the bootloader. For most people who brick their Crazyradio, the bootloader is fine but can't be entered due to a broken main image. Reflashing just the main firmware is sufficient. But without the bootloader in flash the micro goes into deep space when the PC requests DFU mode. No way out now without the SPI wires soldered back on.
GOTO 10
Soldering the wires a second time went quickly since all the wires were still on the double sided tape jig and were tinned. I just needed to flux the PCB joints and tack the wires back on.
Fortunately, someone had posted a full flash image for the Crazyradio containing only the bootloader and rigged to go straight to DFU on the Bitcraze forums. But before that, I wanted to fix a big mistake I made earlier.
In erasing the infopage, I also erased the factory unique serial number. The datasheet has a warning that I missed to back up the CHIPID field before erasing the infopage and write it back afterwards. The source to Crazyradio is able to read this, though I'm not clear what it's used for.
My ten line mod grew significantly since I added this feature in the ugliest way possible. But since I lost my CHIPID, my first attempt writing this included an override to use my own (c0 ff ee fa ce).
After bashing in the new CHIPID, I did a full run with the bootloader image. It took over an hour (it's sloooow!) and failed on the last byte.
Argh.
GOTO 20
The original code writes 2 bytes at a time to flash and doesn't deal well with partial writes, so the last byte got cut off when writing this image. So I did the lazy thing: pad the image to an even 32768 bytes.
Another hour and some desoldering later, I tried the flash update again. This time the micro started up in DFU mode and the DFU app wrote the latest image right away.
The code and the padded bootloader image are in the github repo in the sidebar.
Does it work?
Yes. cfclient and the Crazyflie see each other and all the telemetry shows up including the console logs.
It's good to about 30 feet before it loses signal. That's about what a usual wireless mouse or keyboard gives.
ajlitt
