Well, I sprinted through the week and got the shredder working!
Found the master link I needed to close the chain.
split the chain to the length I needed, and hooked it up to the sprockets.
I'm very pleased that it fits nicely over a bucket. I don't have to lug it out to the bin any more!
Everything plugs in and is running smoothly with no load. Of course, it has to be tested properly.
I went full-force with all tests and used large carrots. they are the toughest pieces of food that I know the 3D-printed teeth can handle. that meant that any issues would be due to the upgrades.
The first test was a complete failure. As I suspected, the hose clamps did nothing to restrain the tremendous torque this motor is capable of putting out. The chain was also a bit too loose and liked to skip teeth.
Back to the drawing board. First I increased the size of the motor mounting plane
Finally I located the motor in place and secured the mounts to the base with screws. I cut the corners off to clear the hopper.
Thank you for your interest!
