The bench itself is made of Pine with heavy duty lockable castor wheels on the legs.
The workbench backing was built using PERI GT24 Girders screwed together with M8×120mm coach screws, and topped with 9mm veneer coated shutter ply.
Mobile, Modular, Enough plug sockets, make it strong enough so that I can disassemble a V8 engine on it if I wanted to...
