So the current design that I was working with was a failure. The axles are too small to be reliable/robust, so I think I will need to rethink my design and probably use metal axles, which also means I probably should just design it to use bearings at all rotation points. Or at least delrin bushings to reduce friction.
So I'm back to the drawing board on this one, but failure is a part of learning.
