Breadbord setup
A project log for Soft Propeller
DIPFORTy1 "Soft-Propeller" Zynq-7, Dual CortexA9+ FPGA DIP40 Parallax Propeller I compatibles footprint
antti-lukatsAntti Lukats • 08/17/2015 at 17:15•0 Comments
When it works the power consumption should be less 1W
Black is 0V GND and red is +3.3V, also clearly visible are the DIP switch setting on the JTAG adapter
There is 2x5 pin header on the module, the adapter has 2x6 socket header, correct insertion as above.
