This may sound like small thing, but we have ready to ship Flash image that can either boot ARM Code from SD Card, or then execute multiboot process and configure every thing from second (application) Image in Flash.
The second image could be Soft-Propeller or any thing else.
Of course the code that would be loaded from SD Card can also configure the FPGA and load more software code from the SD card or the Code loaded from SD Card can update the Application image in Flash, so with next reset without the SD Card the new application would be loaded from SPI Flash.
Is there a location where the code for this is being released?
