SmartEE uses a simple text based protocol on port 1336. You can access it directly over telnet but the easiest way to integrate it into your project is to use the python module [plug.py]. This module encapsulates a plug object and provides direct methods to read data, erase the SD card, set the RGB LED, and of course turn on and off the relay. It can be directly incorporated into any Python project with minimal dependencies. You need [sockets] for TCP/IP communication, and [serial] for USB communication. There is currently a dependency on [numpy] for the data processing but this isn't strictly necessary. However, most projects manipulating power data will probably want numpy anyway.
[demo.py] facilitates shell scripting applications and to demonstrates the usage of [plug.py]. Running [demo.py] with the help flag shows the documentation and example commands:
usage: demo.py [-h] [--relay {on,off}] [--read] [--usb] [--erase] [--file FILE] device demo.py John Donnal 2015 GPL v2 (see LICENSE) This demonstrates some of the capabilities of the SmartEE plug control board Usage: 1.) Control plug relay: python demo.py --relay on 192.168.1.4 python demo.py --relay off 192.168.1.4 2.) Read meter over WiFi, appending to a data file python demo.py --read 192.168.1.4 3.) Download data over USB, appending to a data file python demo.py --read --usb /dev/ttyACM0 Data files created by this script are CSV formatted with the following columns ts | vrms | irms | watts | pavg | pf | freq | kwh ts | timestamp (UNIX milliseconds) vrms | RMS Voltage irms | RMS Current watts| Watts pavg | 30 second average of watts pf | Power Factor freq | Line Frequency (Hz) kwh | Energy used since plugged in (kWh) ----------------------------------------------------- positional arguments: device Device: either a /dev/NODE or an IPv4 address optional arguments: -h, --help show this help message and exit --relay {on,off} Set relay state --read request meter data --usb plug connected by USB, specify device node, *not* IPv4 address --erase erase data after reading --file FILE destination file for meter data
These files are in the [software] directory of the git repository. Check it out! - and of course if you have any questions please let me know!
