FT245 + Actel Stamp + RJ45 Connector, all designed to fit low cost plastic enclosure, 2 layer PCB.
Actel FPGA was programmed with AVR Compatible soft-core that loaded its program from I2C eeprom. FT245 protocol conversion was done by the embedded firmware.
