ESP8266-01 breakout board
breakout board for ESP8266-01. Forked from https://hackaday.io/project/5728-esp8266-01-breakout.
A breakout board for ESP8266-01 module.
Built during KiCad workshop at Maker's Asylum for Hackaday Prize Worldwide Event
https://hackaday.io/event/6438-hackaday-prize-worldwide-new-delhi
ESP8266 Breakout Board, Bill of Materials
Id Designator Package Quantity Designation Description Mfr. Package Mfr. Mfr. P/N Dist. Dist P/N Price/1 Link
1 C1,C2 Capacitor5x6RM2.5 2 10uF CAP ALUM 10UF 20% 25V RADIAL Pitch : 0.098" (2.50mm)
0.157" Dia (4.00mm) x 0.276" Height (7.00mm)
Panasonic Electronic Components EEA-GA1E100H Digikey P15799CT-ND 0.35 http://www.digikey.com/product-detail/en/EEA-GA1E100H/P15799CT-ND/3831166
2 D1 LED-3MM 1 LED LED 3MM HI-EFF RED DIFFUSED Round with Domed Top, 3mm (T-1), 3.00mm Lite-On Inc LTL-4221N Digikey 160-1139-ND 0.33 http://www.digikey.com/product-detail/en/LTL-4221N/160-1139-ND/214530
3 P1 Pin_Header_Straight_1x03 1 V_SEL CONN HEADER .100" SNGL STR 10POS Pitch=0.100" (2.54mm)
Number of Rows=1
Through Hole
Sullins Connector Solutions PRPC010SAAN-RC Digikey S1011EC-10-ND 0.3 http://www.digikey.com/product-detail/en/PRPC010SAAN-RC/S1011EC-10-ND/2775244
4 P2 Pin_Header_Straight_1x06 1 FTDI As above
5 P4 Pin_Header_Straight_1x03 1 TX_SEL As above
6 P3 Pin_Header_Straight_2x04 1 ESP-01 CONN HEADER 8POS .100 STR TIN Pitch=0.100" (2.54mm)
Number of Rows=2
Row Spacing=0.100" (2.54mm)
Through Hole
FCI 67996-408HLF Digikey 609-3391-ND 0.32 http://www.digikey.com/product-detail/en/67996-408HLF/609-3391-ND/1487877
7 R1 Resistor_Horizontal_RM10mm 1 1k RES 1K OHM 1/4W 5% CARBON FILM 0.091" Dia x 0.256" L (2.30mm x 6.50mm) Stackpole Electronics Inc CF14JT1K00 Digikey CF14JT1K00CT-ND 0.1 http://www.digikey.com/product-detail/en/CF14JT1K00/CF14JT1K00CT-ND/1830350
8 R2,R3,R4,R5 Resistor_Horizontal_RM10mm 4 10k RES 10K OHM 1/4W 5% CARBON FILM 0.091" Dia x 0.256" L (2.30mm x 6.50mm) Stackpole Electronics Inc CF14JT10K0 Digikey CF14JT10K0CT-ND 0.1 http://www.digikey.com/product-detail/en/CF14JT10K0/CF14JT10K0CT-ND/1830374
9 R6 Resistor_Horizontal_RM10mm 1 1k8 RES 1.8K OHM 1/4W 5% CARBON FILM 0.091" Dia x 0.256" L (2.30mm x 6.50mm) Stackpole Electronics Inc CF14JT1K80 Digikey CF14JT1K80CT-ND 0.1 http://www.digikey.com/product-detail/en/CF14JT1K80/CF14JT1K80CT-ND/1830356
10 SW1 SW_PUSH_SMALL 1 RST SWITCH TACTILE SPST-NO 0.05A 24V 6.00mm x 6.00mm TE Connectivity Alcoswitch Switches 1825910-7 Digikey 450-1804-ND 0.1 http://www.digikey.com/product-detail/en/1825910-7/450-1804-ND/1731414
11 SW2 SW_PUSH_SMALL 1 GIPO0 SWITCH TACTILE SPST-NO 0.05A 24V 6.00mm x 6.00mm TE Connectivity Alcoswitch Switches 1825910-7 Digikey 450-1804-ND 0.1 http://www.digikey.com/product-detail/en/1825910-7/450-1804-ND/1731414
12 U1 A1117 1 AP1117D33 IC REG LDO 3.3V 0.8A TO220AB TO-220-3 STMicroelectronics LD1117V33 Digikey 497-1491-5-ND 0.62 http://www.digikey.com/product-detail/en/LD1117V33/497-1491-5-ND/586012
13 - Shorting Links, Jumpers 2 -- SHUNT JUMPER .1" BLACK GOLD (1 x 2), Pitch=0.100" (2.54mm) 3M 969102-0000-DA Digikey 3M9580-ND 0.1 http://www.digikey.com/product-detail/en/969102-0000-DA/3M9580-ND/2071621
View all 2 project logs
View all instructions
