the whole system is being rewritten as of now, and I'm using more classes, as this keeps code nicer to look at, but also increases security on the user app-side:
it was this before:
all system variables and functions can be adjusted/called from your own apps. to prevent this from happening, simply declare all variables in the 'private' section of your app.
And for the functions, recommended is using __ in front of every function you make, example: 'void __init_vars()'.
and now it is:
no system variables can be accessed, and only functions that are set as 'public' can be accessed from apps now :D
this enhances security of the watch.
this also means one can not access the graphics library directly (including all driver chip commands), so a 'wrapper' is being written as well.
the gihub repo will hopefully be online by the end of this or next week
