boards are ordered
A project log for USB cable tester
I want something usb stick thingy-ish to check a usb cable
davedarkodavedarko 07/21/2015 at 16:340 Comments
Let's see what the prototype will be like - it's a battery powered attiny, that will be awakened when you hit the reset button and goes through it's routine. Once it's done, it will go to sleep again.
I could add an XOR chip as well and feed the output back to the arduino.
