So the code from last time didn't work at all, when I woke up the blue LEDs where totally dim. I've check the datasheet for the attiny45 and noticed once again - what works on an arduino must not work on a board using non-atmega328s. I hooked up my new UNI-T UT61E and measured 200uA - not the 0.1uA I've expected to see. With the help of the gist from JChristensen I verified (read copied) my code for the power down and measured a success - yes it's measurable - 0.1uA !
Things to safe power, according to datasheet:
- turn off adc (not needed for LEDs)
- turn off brown out detection (BOD)
- turn off analog comparator
- turn off internal voltage reference
- turn off watchdog timer
- disable port pins per register
With the help of JChristensen/AVR Sleep
https://gist.github.com/JChristensen/5616922
#include <avr/sleep.h>
#define BODS 7 //BOD Sleep bit in MCUCR
#define BODSE 2 //BOD Sleep enable bit in MCUCR
int leds[] = {4,0,1,2};
void setup()
for (int i=0; i<4; i++)
pinMode(leds[i], OUTPUT);
digitalWrite(leds[i], HIGH);
delay(200);
digitalWrite(leds[i], LOW);
delay(200);
die_until_reset();
void loop() { }
void die_until_reset()
byte mcucr1, mcucr2;
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_enable();
MCUCR &= ~(_BV(ISC01) | _BV(ISC00)); //INT0 on low level
ADCSRA &= ~_BV(ADEN); //disable ADC
cli(); //stop interrupts to ensure the BOD timed sequence executes as required
mcucr1 = MCUCR | _BV(BODS) | _BV(BODSE); //turn off the brown-out detector
mcucr2 = mcucr1 & ~_BV(BODSE); //if the MCU does not have BOD disable capability,
MCUCR = mcucr1; // this code has no effect
MCUCR = mcucr2;
sleep_cpu();
