I went into a bit of a tizzy just now. I looked up the AD5601 thinking that it was the DAC that I had picked, and discovered it was an 8 bit part. I then went on a search for a replacement and then realized that I had meant to say AD5061, which is the 16 bit part with the mid-point POR behavior that I had thought it was.
Whew.
