Hackaday.io Hackaday.io
Sign up Log in
AVR Soldering Iron
A first attempt for a small, attractive and practical soldering station, a project designed not by the cost but rather the experimentation.
manosManos
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3.6k views
1 comments
3.4k followers
  • Description
  • Details
  • Files 13
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 1
View Gallery
3.6k
1
3.4k
11
Team (1)
  • manosManos
Join this project's team
  • DIY-SMD-Soldering-Station
completed project
MISC
avr atmega2560 soldering iron
Related lists
SOLDERING STATION DIY
RACCOLTA STAZIONI SALDANTI DIY BASATE SU MCU STM
This project was created on 02/28/2018 and last updated 2 years ago.
Description
A DIY Soldering Station with ATMega2560 and SMD partsMany thanks to Matthias https://debugginglab.wordpress.com/2014/10/30/soldering-station/ for the inspiration. There were some improvments to UI with insertion of bargraphs for desired and actual temperature, indication for memory saved last desired temperature and settings with rotary endoder instead of pot.It would be also a remiss not to thank Stefanos Tselepis (FireDeveloper) https://github.com/FireDeveloper for his aewosome RGB MultyBit Calculator. It helped a lot for developing code with MCUFRIEND small TFT.From version IRON_18 and later, the combatible TFT is this:
Details
Files
DEFINES.h
h - 4.52 kB - 02/28/2018 at 18:50
Download
UTILITY.ino
ino - 3.53 kB - 02/28/2018 at 18:50
Download
TFT.ino
ino - 10.29 kB - 02/28/2018 at 18:50
Download
INTERRUPTS.ino
ino - 2.15 kB - 02/28/2018 at 18:50
Download
IRON_20.ino
ino - 7.16 kB - 02/28/2018 at 18:50
Download
View all 13 files
Log In/Sign up to comment
Sign up with Github
OR
kostas wrote 03/09/2024 at 11:03 • point
hello. this project is tested?
In this project, you will learn how to build a system to function as a temperature indicator for Arduino.
Project Owner Contributor
PCBWay Temperature Indicator System
silcios-labSilícios Lab
Temperature controlled proofing box for dough/bread.
Proofing Box
michaelMichael
This project will keep your garage fridge/freezer working properly during cold winter months
Garage Fridge Thermostat
rockfishonrockfishon
A light that displays the temperature outside as color
OrbLight
petereiterpete.reiter
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "AVR Soldering Iron", please tell us the reason.
Send message
Remove Member
