days of mushy-brain
08/10/2015 at 10:28 • 1 comment![]()
This is the initial-concept for a snap-together drum/driver-pulley... two "forks" cross-over each other and pass-through each layer of lasered-circles. (despite using transparency, the renderings don't show the forks passing-through the cylinders).
I'm trying to figure out how to account for material-thickness variances (they only guarantee 10% tolerance)... so I'm thinking "forks" coming from each side with serrated edges that when compressed together will ratchet into ever-tighter compression. It's frustrating, at this point.
Also trying to figure out how these pulleys will actually be mounted... so-far I'm thinking two additional small-circles (like the red ones) on either end (outside the green)... these'll ride inside a cutout mounting-plate on either-side. It's hokey, and the amount of drag...? yeah. But it's the best I can think of. Makes hand-driving a bit difficult, having to maneuver your fingers around the mounting-plates... but, again, it's the best I've come up with. Maybe a crank extending from one of the forks on the outside of the mounting-plate, but then there's torquing on one "fork" which might cause twisting... I'm not opposed to glue, but I'd *like* to not need it in the long-run.
Initial calculations suggest the driver/drum pulley can have arelatively small radius and still have the cable physically attached to
the drum at one point, just a few (ten-ish?) turns are necessary for full-motion, so no need to worry about slippage...
Anyways, for attaching the motors, I'm visualizing yet another circle with a +-shaped cutout that slides onto the protruding part of the "forks"... But, the + doesn't really work with a motor-shaft attached in the center... so then a four-hole mate at the bottom (in the image) with longer fork-prongs...? But, then, there's the serrated/ratchetting thing that was discussed earlier... so, yeah... my brain's gone to mush again.
In reality, this whole project is ridiculous... and more-so trying to do it without a prototype or ten of these various mechanisms. I've got a perfectly good inkjet-printer mechanism just waiting to be hacked into a 2-axis system... attach a dremmel and probably could make many of these parts for prototyping...and, yahknow, what was the original purpose of all this, again? I think, somewhere in all this, was the idea "yahknow, it'd be nice to have access to a CNC-machine to make cases for things, etc..." which would certainly be a heck-of-a-lot easier to do off-the-bat with this lasering-order...
Oh, and, apparently the bit-banged UART receiver isn't working yet, which is surprising, to say the least, as I/O is clearly working, and precision-timing is clearly working, as well... Seems like that'd've worked pretty much right-off-the-bat. Is it the 3.6V signals feeding into the 3.3V Inputs? No, I tried feeding through a diode and a pull-up at 3.3V... so...? And the outcome is *really* weird... it seems to be echoing *several* 0xff's each time I transmit *one* byte to it. (and raw transmission from it, rather'n an echo, works perfectly fine). So, yeah.
(WAIT! Is it the fact this system's so fast...? I might've forgotten to increase those timer-comparison integer-sizes on the receiver, as I had to do on the transmitter.... TODO!)
Yeah, this is all as of several days ago, I'm just trying to remind myself the status.
Look at all those 5V tolerant pins!
08/04/2015 at 02:02 • 0 commentsI started out with the PIC32MX230F064B, for some reason... I also have the PIC32MX170F256B... I figured I'd continue with the one I started-with, but already ran into some (minor) difficulty: my USB->Serial converter uses 3.6V-TTL, whereas the PIC32 is running on 3.3V. Really, in this world, that should be acceptable, right...? 's just a hack at this point! Well, it ain't working, and I guess that's the first thing to check. Could it be causing "latching-up"? As far as I'm aware, never, in all my years, all my TTL and AVR circuits, actually ran into a case of that.
Anyways, the MX230 has a few 5V-tolerant pins... but apparently none that aren't already in-use. We've the JTAG pins, reset, and one dedicated to detection of the USB-Bus, that's it. Then there's the MX170, which appears to have 3 regular-ol' GPIO pins which're 5V-tolerant and have nothing to do with USB or JTAG. Nice.
...And, apparently I'm slow, because of course, I could just implement USB->serial in the MX230 itself, right? (That's *way* over my head, at this stage).
Anyways, my motor-driver communicates via 5V signals, so there's that.
The actual laser-cut mechanical design is somewhat on-hold. I completely burnt out on it a few days back. Though on-paper I think I came up with what to do about the "drum"/driver-pulleys and how to "snap" them to motors.
not today...
07/27/2015 at 14:30 • 0 comments![]()
Oh, and those wheels make contact with the bed for 1.5mm, hah!
Basically, if you're not looking at this on a phone-screen, the image is probably significantly larger than the real-thing. The file is nearly 3000 lines. This is absurd.
Hey, everything seems to scale nicely, at least... 'cause yahknow, a large pulley-driven 3-axis system makes a heck of a lot of sense.
Also, are those two diagonal pulleys going to cause weird torquing? Bah!
Those'll be nothing compared to the rest...
WTF...
Yesterday: (before I passed-out)
The "deadline" for a free first $20 order passes in something like 15 hours...
My brain has turned to mush on this project...
The latest:
Thought I'd switch to merely 2-axes for the $20 order, as a good proof-of-concept, and plausibly still functional as an etch-a-sketch sorta thing...
Glad I did; viewing it with less clutter made me realize several *more* design-flaws WEE!
Even the pulley "puzzle" idea is a bit difficult in this short time-span... Turns out some of my pulleys need to be rotated 90-degrees, which means they're no longer mounted on my surfaces, but require *additional* surfaces... Whelp, that's a bit of work, and adding those surfaces interferes with those that woulda been used in the "puzzle". So...
I kinda still dig the idea of a system that could be implemented in a mere 7.1in x 7.1in piece of material... But the monetary-crunch for it is dramatically-reduced with the $100 gift...
I've little doubt I *could* get a 3-axis, probably even 4-axis something within $100, and probably even a few other things, as well.
So... seeing as how this $20-free additional surprise was limited to ten days... well, let's just say I can't even remember the last time I bathed.
[Note 2023: LO Friggin L! What was it three measly days? My how times've changed. I lost my beloved cat two years and six months ago in a few days. Last I bathed with anything other than lysol wipes was looking for him at a hotel! No joke. LOL I laughed so hard reading this I started to pass out thinking "well, this wouldn't be the worst way to go!" This ain't a call for pity. I'm fine. It's just incredibly funny to recall a time prior to "living in a van down by the river!"]
I think it's time to admit defeat.
It woulda been good to do a prototype before "the big order", though, since there's something to be said about the effects of tooling-widths and whatnot, that could have a dramatic effect on a system like this... Also, was kinda thinking about snap-together, which *definitely* would be effected by tolerances, tooling-widths, etc...
too tired to write...
07/26/2015 at 00:16 • 0 comments![]()
big bite + pulley-configurations
07/24/2015 at 10:07 • 0 commentsI mighta bit off more than I could chew... was trying to get a functional-prototype done in ten days (first order free up to $20!), but my brain just stopped (or started?) working today...
Found yet some more design-flaws, even in reverting to that which was well-established (on paper)... the one that doesn't lend itself well to 3D... And those issues just started piling up to an insurmountable level, today.
The pulley-system I was planning to use for the third axis causes torquing on that axis... OK, fixed, now there's four more pulleys and two more cables... per axis (woot!)
Then... aww, I can't remember...
Oh, Tried to keep the openSCAD model easily-swappable between the two designs (3d-friendly vs. not) but now neither of them are working... MATH. Gave up on the 3d-friendly model for the "deadline", and still can't get the 2.5d model back to where it was... Wee!
On the plus-side, I did some cleaning today... the cat knocked over a box full of books, greeting-cards, and playing-cards... it's been quite a mess for weeks. And she's been using my books as scratching-posts! Also the rolling-table/workbench had a larger surface about two months ago... I replaced that surface with a smaller one, but never retightened the screws, much to my buddy's shin's chagrin. So, that's fixed, too, ish.
The "deadline" fast-approaches, and I still have to figure out how to convert the 3D model to 2D SVG for cutting, which is another huge mental hurdle at the moment. I know how to do individual parts, but this thing is a 3D model of *all* the parts, put-together... So, we're about halfway through till the "deadline" and at this point I'd already planned to start the 3D->2D process, and I don't have a full system yet to even attempt to do that with.
So, now, I have this crazy idea that if it's gonna be a snap-together "kit" of sorts, then why not have a bunch of pulley-locations available (holes already "drilled"), and make it a bit of a puzzle (kinda like the Cordwood Puzzel), like the puzzle that's going-on in my head the past few days (and 10+ years)...?
This "kit" could be supplied with instructions to build the model itself, but leave the pulley-locating as a challenge... 'cause that's how it's gonna be if I attempt to meet this "deadline" ;)
Anyways, I know the pulley-system *can* work; I've *done* it... and, if done-right, they actually add to structural-stability as well as smooth linear-motion/reduced torquing... But, can it be "done-right" in this new orientation/layout? Remains to be seen. Pulley-Mount-Holes Everywhere!
As far as pulley-layouts... there's a couple options... The *easy* one, requiring the fewest number of pulleys, makes each axis dependent on the others... e.g. if X moves 5mm, then the Y motor must move 5mm to compensate... This sucks as far as "glorified etch-a-sketchs" goes... but isn't hard to do in software... The "easy" one, requiring the fewest number of software-hacks (and being compatible with a "glorified etch-a-sketch") requires nearly double the pulleys. On the plus side, it means that each axis is completely independent of the others. This concept I dig. And it lends itself well to the "glorified etch-a-sketch" idea. Again, software-wise, it's completely unnecessary... how hard is it to say "Y=X+y"? But, again, LOTS more pulleys and cable routings.
And, frankly, the harder-software-hack version lends itself well toward testing the precision of multiple-axes WRT each other... which is something that could be worthy of attempting...
So... maybe... the solution is what I came up with earlier... lots of mounting-holes for various pulley-configurations.
3D
07/23/2015 at 14:57 • 1 commentThis one's a stretch...
It certainly clears up the 3rd-axis clearance-issue, but:
* may be quite a bit more difficult to run the cables/pulleys
* might not be stable-enough for merely two casters on the 'bed', should I use four?
(otoh, now that I think about it, part of the niceness-discovered with the pulley/lego system was that the cables, when positioned and tensioned well, actually add to overall stability quite-nicely)
* appears to use quite a bit more material for the same travel-distances...
* more difficult to add support left-to-right... may need longer bed-casters...
* can't add front-to-back support in the front
* kinda bulky/ugly...
Nicities:
* lots of vertical clearance for potential 3D-stuff....
* easier to make the Y/Z carriages larger, to mount larger things (dremmel-tool?)
* The Z-axis should be *quite a bit* stronger
* (maybe the Y, as well?)
* The Z-axis carriage and associated cable-tensions might actually add some stability
things to think about...
design flaws...
07/23/2015 at 08:04 • 0 commentsRan into a few design-flaws along the way...
First was this:
Yeah, that's a 2.5ish-D system, and that third-axis... how the heck was I planning to transfer motion to Z for the pen-up/down...? Came up with some lever-system (the teal thing in the middle) but it seemed pretty wonky, to say the least. Also, this system requires pulleys to be *really high* off their attached-surfaces, which would cause some torquing on the material...
This is what I'm on, now:
Was pretty proud of that, have it even more completely-drawn-out on paper... including the pulley-layout which results in very little torque. But just realized another design-flaw... Always figured the Z-axis wouldn't be particularly strong, what with the number of pulleys it'd have to go through, but certainly good 'nough for a pen... but, I was kinda hoping to at least have the *option* for 3D-something... who knows what... Well, this doesn't lend itself to that well, at all... the Y-Axis carriage would hit whatever 3D thing was under it. Woot!
Early pen-and-paper sketches suggest swapping the Y and Z axes... have Z be the vertical plate attached directly to the X gliders, then slide Y left-to-right on that... Great! Except... very little stability, I'm sure. It'd require cutting out a significant amount of the structural-support provided by the Y (now Z) plate, and all that that was going to go behind it.
We'll see... Again, this was mostly just to get this darned pulley-thing out my system; a glorified etch-a-sketch would be a great start...
Here's the wheel-plates... I'm particularly proud of the red-wheel-mounts which are snap-in. Though, I'm still trying to figure out what to do about the green-wheel spacing, which would be offset by the laser's tooling-width as well as tolerances in the material-thickness...
Thinking about a diagonal notch and screws... it's vague in my mind, so far.
The whole system is designed to be easily-scaled, so I'm kinda thinking about the smallest-size sheets they have available 7in x 7in, and possibly trying to fit everything on a single sheet... A tiny little cartesian system for fun. Maybe even snap-together... held together still as a sheet which can be snapped-apart... I dunno.
The only things necessary besides the lasered-material, then, would be cable, pins, (glue?) and pulleys... and I'm contemplating how to cut a notch into laser-cut cylinders with the tools I have available...
Eric Hertz
