11Step 11
When the blinking stops it means that your socket has been discovered. Click remember.
12Step 12
Now you can turn on and off from any browser. Prota OS supports remote access so you can control your appliances even when you are outside of your home network.
13Step 13
We recommend making a shortcut on your smartphone’s home screen.
14Step 14
If you wish you can make advance automation stories. E.g. add a Bluetooth module and install RFID app. Then you can set Prota to turn on your socket when you are present in the room and turn it off when you leave.
15Step 15
Enjoy!
