A project log for OpenBuilds C-Beamâ„¢ Machine Build
C-Beam Machine is a CNC machine design based on the popular V-Slot linear guide system.
testing the linear rails with some weight
Did you consider using a Ball Transfer Unit instead of the rail?
i didn't , i had the rails lying around so used thouse
Ah I see. Thanks for sharing the project, it has helped me plan my C-beam build!
Yes, delete it Cancel
