Spindle mount and various
A project log for OpenBuilds C-Beam™ Machine Build
C-Beam Machine is a CNC machine design based on the popular V-Slot linear guide system.
charliexcharliex 07/26/2015 at 22:300 Comments
We need
add these here, i'll have to see where these are attaching to, they're meant to go in channel so they have little nubs to help align, if they're not rotated in channel, i usually remove them but lets see what happens.
so add the 90 corner brackets with the 10 mm M5's to the underside of the gantry to the 4 T-Nuts, one of my T-Nuts had damaged threads, so note to self check before installing that they thread OK, often its a pain to get back to them.
same other side
add the router mount, 4 black right angle brackets, not these do have the nubs like the others which is good.
they go on the inner holes of the 4 available.
squared off
mount on the z gantry. 4 more 10 mm M5's, square it here as well, though we can adjust later.
always hard to photograph.
add the front part of the router mount, 2 X 20 mm M5 bolts
and put in place, mine didn't thread all the way, since no spindle in place
And another stage done...
ext it's the build plate, I'm going to take a break for some coffee.
Rich text editor
