At the last week I also did some (very small) changes in the Bluetooth communication and updated the android app.
The app is now able to view and change the following list of things:
- enable/disable the color processing
- reset the system
- switch to the next video input (There are several input ports: 1xHDMI, 4xCVBS, 1xYPbPr, 1xRGB)
- "performance configuration" because the AmbiConbtroller is much faster than my TV, so It has to be throttled
- set the brightness
- offset color output (RGB)
- white balance (as a percentage RGB value)
- output color if no signal is detected (RGB)
