In the last months I habe eine a lot of work to improve the system update functionality.
Now it is possible to update the FPGA design, which is stored in a small SPI flash, with a simple terminal tool (called fpga_flash) using USB.
I also modified the Bluetooth communications protocol, so it is now possible to configure the channel and LED strip configuration.
With those improvements the enduser is now able to do everything he needs to do if he wants to set up a new PCB or TV setup.
klaute
