Single Layer PCB, ethed at home using heat transfer technology. Lattice XP was the FIRST flash FPGA available at that time. Part of the IP core sources have been re-used in later projects.
SD Card emulation with Lattice XP FPGA
Hi Antii,
I'm looking to build my own SD card emulator for a project. Is the FPGA code available for this project or is there some reference code out there for SD card emulation?
Regards
Matt
Hi guys,
At present what are the CMD that it's possible to emulate?
Is it possible to use both SD and SPI or only one of them?
Thanks and regards
SDHC
I am curious, are Lattice dev tools easy to use? Xilinx ones aren't great, I was wondering if Lattice got them right.
