I want to add a speaker and meter to a Sparkfun Geiger counter module. I wish they had broke out more pins from the microcontroller.
I needed to add some wires to the pins.
Here is what I have so far:
https://youtu.be/S90JSTjxOEk I toggle the speaker on signal. The meter is connected to a PWM output and has a sum - decay function that adds a value on click and then slowly decreases.
I need to add a scale control (low-med-high) so I don't pin the needle. And I need a nice box.
