Rosace
Persistance of vision mill. Or a 2m diameter RGB rotating screen.
Fred Sapey-Trimphe builds persistence of vision mils since 2009, called SPIM or e-Rosace.
http://www.mepic.fr/?page_id=494
Since 2013, the Rosace displays actual color videos at 15fps with a Raspberry Pi for storage and rotation computations, hooked to a FPGA for the tight real time signals and angle interpolation.
https://www.youtube.com/watch?v=v7z_S63g47M
https://youtu.be/x2YBD7hN7RU?t=1m32s
Logs:
1. Rosace v1.5
2. It's getting out of hand
View all 6 components
  • It's getting out of hand
    Yann Guidon / YGDES • 08/17/2017 at 14:12 • 0 comments
    The new controller system now looks like this :
    I hope it's enough because there is no room left now :-D
  • Rosace v1.5
    Yann Guidon / YGDES • 06/15/2017 at 22:44 • 0 comments
    A new version of the Rosace is being developed, hopefully for an exhibition in September.
    The upgrade is significant :
    • 25 fps instead of 15
    • 200 LED diameter (instead of 120)
    • Faster, synchronous (2-wires) LED strips
    • RPi 3B+ instead of Pi B (v1.2 from 4 years ago)
    • Introducing the 3RGB (de)compression algorithms (see #3RGB image lossless compression format)
    • simplified auxiliary circuits in FPGA
    • Multi-threaded programming (yeah! 4 cores!)
    So it's a significant evolution but not a revolution, yet...
    Stay tuned !
View all 2 project logs
