A hidden gem with our new e360 classroom loggers: the 0.49” micro OLEDs only draw about 3-400 µA and sleeps ~6µA! So you can have screen output like this for about same amount of power as an indicator LED and that means you can run them on a Cr2032! Since they use SSD1306 controller they can be made to work with standard libraries provided you compensate for mis-match between the origins on screen and the origin in the controllers 1K memory.
https://thecavepearlproject.org/2023/12/01/the-e360-a-classroom-data-logger-for-science/
Ed Mallon
