Bluetooth RC Car
2007 - my first extensive project
After freshman year of college, I finally fulfilled a childhood dream of acquiring an RC car. I gutted it and rewired it to use hobby servos controlled by my computer via a bluetooth serial adapter. I didn't want to spend money on PWM motor driver, so I used one servo with a big rheostat for speed control, and a second for a horrifically janky motor direction control. As is traditional in true hacks, I of course had a VB GUI for controlling it. And it worked great!
  • 1 × NIKKO Alienator RC Car Seems to be from the 80s, so it's as old as me?!?
  • 1 × IOGEAR Bluetooth 2.0 Serial adapter
  • 1 × Serial to TTL adapter
  • 1 × MiniSSC II Serial servo controller
  • 3 × HS 422 servos
View all 8 components
Keenan Rebera wrote 04/28/2016 at 00:54 • point
What motors / battery did you use? What was the battery life, and how fast could it go? Any tips / regrets? Sorry for the bombardment, but I'm looking to do something similar.
Gertlex wrote 06/02/2020 at 22:45 • point
I recall reading this question, but apparently forgot to answer years ago.  I used the stock motor; if my research at the time was correct, this model car was already 20 years old. It had a compartment for 7.4V NiMH batteries, which I bought off ebay or similar at the time.  I think I could get around 15 minutes of run time before the speed went down a bit? Maybe a bit less.  Speedwise, pleasantly fast!  One time, the bluetooth connection stopped (computer went to sleep when I closed the lid, and was attempting to drive with a usb keyboard? unsure), and I had to run to try to catch it... it found a wall before I could get to it, but was ultimately fine.
Zero regrets. I'm familiar with better electronics these days (and better stuff is available, too), so would do it in some manner differently if I were doing it today.
