A Flex Module wearable sensor.
Tank circuit antenna sensing electromagnetic activity 500KHz-2MHz. Designed to use i2c. There is some internal tuning and indoor/outdoor and some other driver configuration that needs made for good function. Should be kept away from other electronics to limit false positives.
Any software related will be released under BSD or MIT license. SAAS or cloud based software will be AGPL.
Chris Hamilton
Michel Racic
VASILIS VORRIAS
