Mobility is a huge developmental milestone that imparts benefits in vision, spatial awareness, and cognition. Many children with cerebral palsy and other similar disorders have manual chairs, but may lack the coordination or control that would allow them to receive a power chair. Further, power chairs are exceptionally heavy and not always conducive to the trial and error needed to learn to use a power chair. (Imagine driving into walls, windows, and little brothers).
Therefore, the stated goals of this project are to develop a product that is:
1) Inexpensive. Under $150, hopefully half that.
2) Easy to attach and remove. Less than 20 seconds. Targeting 10 seconds for attach or detach.
3) Low Power. Needs to be strong enough to drive at least 100 lbs, but low enough power that it will stop if it hits something or someone.
4) Low speed. Keeping in mind that this is a first foray into mobility, the point here is the ability to move and explore.
Okay, so I'm pretty stoked about this-- Triad Semiconductor finally has the castellated TS3633 modules in stock. These are the light -> voltage frontend photodetector modules that go with the Vive lighthouses. If you haven't read about how the Vive lighthouses work for precision tracking, it's a pretty awesome design. But in short, these are a key piece in putting together a crazy-high precision indoor tracking system. Because of the precision and fact that it's royalty free, I'm convinced we're going to see some awesome innovation coming out of this tracking in the next couple of years.
Anyway, I just got my order in and should have them in hand soon to start putting together the tracking piece for the autonomous chair.
There are a lot of strategies for indoor autonomous driving. SLAM, for example seems to be getting really popular. What I've really been hoping for is some sort of indoor GPS solution. I've been keeping an eye out for something like this for years. Until about a year ago, the best bet I could see was some sort of a system that used the time of flight of an ultrasonic signal from multiple beacons (or receivers) along with an RF communication channel to determine location. There are a number of solutions that use wifi and the like for positioning, but precision is on the order of meters. But, in the last year, high precision indoor positioning has come a *long* way.
Pozyx hit the Kickstarter scene last summer, and promised an UWB tome-of-flight solution that promised 10cm precision. I picked one up this spring, and when I first set it up, it was awesome to see my positioning moving around the room as I did. But long story short, it's pretty susceptible to multipath interference and just not reliable enough for what I need.
I'd also considered taping fiducial markers all over my ceiling and using a camera to determine location. While this may work, I never spent enough time going down this path go get it to work.
Then, the Vive came out. If you haven't read up on the tracking technology, it's pretty ingenious. And it sports sub-millimeter precision!!! Right now, I'm waiting for the ts3633-cm1 modules to be available. Once I can get my hands on some, I'll be able to move forward.
Well, it's been a long time since my last update, but progress is ongoing. I've cleaned up all of the electronics and enclosed them in a case. So far, the Shoe Goo has worked very well to increase the friction, and it hasn't peeled off of the ABS, which was one of my major concerns. As a note, I did prep the ABS with acetone immediately before applying the Shoe Goo, which may have increased adhesion. At this point, the primary goal of making a powered add-on for the wheelchair is basically met. But, when I look at my daughter's ability to use this, I see I need to take it farther. The chair really needs to be able to autonomously drive to specified locations. I need to configure this so she can pick a destination in the house using her eye gaze system, and the chair will take her there. More to come soon...
One of the issues I've run into is slippage between motor-mounted drive wheels and the tires on the wheelchair. ABS seems to have a pretty low coefficient of friction. My first attempt to address this was some liquid electrical "tape" I had lying around. I tried both a spray-on version and a brush on version. Both work kinda okay, but they don't look like they'll stand up to long-term stress. They'll just peel off of the ABS over time. For a more permanent fix, I'm thinking a good product to try will be "Shoe Goo." I remember using it as a kid to get more life out of some sneakers, and as I recall it worked pretty well. Since it effectively replaces the sole of a sneaker, it should be both quite tough as well as provide good friction.
I've also found that the screw shield doesn't seem to hold the phono plug wires very well. I'll need to figure out something better. I can easily use a proto shield, I'm just trying to keep the build as simple as possible, especially limiting the soldering to only the bare minimum required for someone to get one of these up and going.
I did get some male and female wire plugs in the mail from China a few days ago, and I've added them so there's now a nice battery disconnect. Still need to add a switch-- I'm thinking a standard household electrical switch will work well, and yet be very inexpensive.
Oh, and I've added a couple of pictures and a short video of the first trial. It's not on the video, but I did try riding in the chair myself, and it had no trouble pushing me around at 160 lbs (73 kg).
This has been a project I've wanted to do for a while, and finally dove into a few weeks ago. I've got a first iteration of the design that is functional.
The basic electrical design consists of an Arduino receiving input from a couple of switches, and driving a Monster Moto Motor Controller board, which is connected to two decent gear motors. Add in the 12V sealed lead acid battery and a 5V regulator and that's all of the electronics needed.
As for the mechanicals, the entire rig connects to the wheelchair via two small brackets mounted to the chair. The main housing slips into the brackets and rotates into place. The drive wheels mounted to the shafts of the gear motors contact the chair's tires. And rubber bands maintain sufficient pressure to ensure the drive wheels are pushed against the tires with sufficient force to avoid undesirably slippage.
The mounting brackets are mostly 3d printed, as are the motor mounts and the drive wheels that mount on the gear motors.
I'm wondering about how this would work with a standard large wheel size chair? Different gear rations needed? Of course a much different mount. At least today battery packs are more readily available and affordable.
I ran across this old project while looking for info on friction drives for wheelchairs. George Klein developed the first electric wheelchair in the mid fifties using a friction drive and a crude joystick. His was a much bulkier creation, I like your concept more. You may see his ideas in this book https://books.google.com/books/about/George_J_Klein.html?id=F1xHwJLeGMAC
What's become of this project? Seems to me a workable idea for a crowd funding page. My wife is in a wheelchair and hates her electric Jazzy brand electric chair. It's a pain to transport as well. Her lightweight standard folding wheelchair with this detachable electric drive would make like much easier. We could easily transport her chair and drive to be quickly assembled once we arrive at our destination.
Hey just saw your project and despite still being in its early stages it looks awesome. I can't wait to follow your project as it progresses. a suggestion or comment i would say is that perhaps a lithium ion battery would be a better fit instead of the lead acid? I know that Lithium Ion have the potential for danger whereas Pb batteries are much safer and time tested so i could see your reasoning there. However with adequate safety measures I think Lithium Ion could work great. It would weigh much less and still have alot of power which would be important in terms of being able to push the desired 100lbs. having a lighter battery wouldn't just mean you have more wiggle room to reach the 100lbs goal but it would also decrease the overall mass of the object so its total force potential would be lower if there was a situation where it did accelerate towards a wall. anyway your project looks amazing and i look forward to seeing your end result.
[edit - just seen the BoM link, thank you!] What motors did you use? What voltage supply? Dual H bridge drivers? What does your control scheme look like? So many questions!
I had issues with the transmission and will post a log soon-ish about how I got the friction between drive wheel and driven wheel "good enough" for now.
