For This Project we will be using OpenCv on the Raspberry Pi quite a lot.
It it crazy Just How much miss information there is about opencv and the Raspberry pi
many tutorials will guide you thru a installation process that takes 12 hours+
and has library linked complexly.
Opencv 2.4.1 [CV2] is available in the default Rasbian Repository.
To Install on Rasbian, type the following into the command terminal:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install libcv-dev
sudo apt-get install python-opencv
sudo apt-get install libopencv-dev
sudo apt-get install libcv2.3
sudo apt-get install opencv-doc
Yet that is it, OpenCv is installed.
How To use:
>Open the File manager and go to your documents
>Right click>CreatNew>Empty File
>Add the line [#!/usr/bin/python] To the top of the file
>Save it as <FileName>.py
>Right Click on the File >Properties>Permisions and select everone> OK
>Doubble click on the file and execute in terminal
Hints:
>Remember it is a python based install of openCV 2
>Execute the python script as root if you want acess to the GPIO pins
>If the script doesnt work, Cd / into the directory and run python <Filename.py>
I will be including a test scrip in my next blog post to check that your installation will work with the raspbery Camera module and a USB camera.
