The hackers Solution to World Hunger will require Vision based control, Processing is a Free and Powerful Tool when it comes to Vision based Control Systems. It turns out Installing Processing on The Raspberry Pi is a little more complicated than it should be, this tutorial will guide you through the installation process.
This Tutorial is based on a Scruss.com tutorial for processing 2.1 . If you are used to the Linux GUI and the use of Commands, then skip the Video and just read the tutorial. If this is your first time with a Raspberry Pi and are finding yourself a little lost making your way around the environment then use both the video and tutorial together.
In order to get a working version of Processing on the Raspberry Pi the following steps must be followed:
>Update the system
>Install and use the Java JDK 7
>Install Processing
>Replace the Java run time with Pi’s own version
Update the system
Check that you are connected to the internet, then open the terminal and follow the commands below:
sudo apt-get update
sudo apt-get dist-upgrade
Install Java
sudo apt-get install oracle-java7-jdk Check if the right version is installed and being used.
java -version
java version "1.7.0_40" is what you should get, if you dont then enter the following Command:
sudo update-alternatives --config java This command will ask for a specific version to be declared, you do this by inputting the corresponding table number into the task manager. Remember you want JDK 7.
Download & Install Processing
Go to www.Processing.Org
And Download the Linux 32-bit Version [around 100mb]
[If you have the funds to spare, Fund these guys. Their work is Awesome!]
Once it is downloaded click to open the file, it will ask you to extract the folder, extract it into the:
home/pi directory [as Below]
Next you need to Run the following two commands, it replaces the java with a compatible R-pi one [Check out Scruss.com if you want a better explanation] .
rm -rf ~/processing-2.2.1/java
ln -s /usr/lib/jvm/jdk-7-oracle-armhf ~/processing-2.2.1/javaThat Is The End of The Tutorial
Now You should be able to navigate to the processing folder:
home/pi /Processing-2.2.1
Click on the Processing Link in there, Execute and Processing should open like below:
Dont Forget To like, Share and Get involved with the "Hackers Solution to World Hunger" Project. The next Tutorials:
> Controlling Raspberry Pi GPIO Pins From Withing Processing Environment
>Raspberry Camera and Processing, Bringing Vision Based Control To Your Projects
Michael Ratcliffe
