The most critical part of this machine is the 3D printer mechanics that actually hold and organize the individual pills. I went through several iterations of this before settling on the current version (that I already want to improve). The first version was a snake of sorts that would slide around the base of the box and could align one of the many individual storage boxes above a pill insertion port. The main challenge I had wasn't getting the pills in but getting them out efficiently.
The latest version I ended up using for this project is based on a rotating barrel. As you can see below in the blown out view, a barrel (blue) with 16x4 slots rotates in a drum (orange). The drum keeps the pills in their individual slots while it rotates. There are holes in the barrel at the bottom and top. Pills can enter the barrel at the top and doors can open to allow the pill to simply fall out with gravity when selected by doors (pink). The selector at the top (green) slides back and forth to select which of the 4 holes to insert the pill into when loaded.
If you want to explore the design in 3D you can download an STL of the blown out design here: https://www.dropbox.com/s/slu101yfu7tsvtf/full machine blown out.stl?dl=0 and a 123D design file here: https://www.dropbox.com/s/i82wmfc3rblamnl/full_system.123dx?dl=0
