You're all set now, go get things that use the framebuffer! I didn't go for X.org, but here's what I tried:
- SDL Quake (remove -mpentium from configure before build)
- Get SDL 1.2: https://www.libsdl.org/download-1.2.php first; the prereqs can be annoying - Google when/if you hit libPNG errors, you just need to rename the NULLs.
- Nano-X (this one took some work to compile, you should use Alex-T's Repos)
- Dosbox (It uses SDL)
- Quake (Yeah, I have two ways to run Quake - weird)
- Warcraft
- Simcity 2000
- Not sure, only tried those three... probably most anything, though.
- DirectFB (I had issues, but lots of demos will run)
The great AlexT's Edison repos: http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html
