Maybe a bit pointless but it helps a little bit with knowing if i'm record or playback mode and I can report what bit depth / FS audio
mode i'm in when I get that working :) but this is a BT only field recorder !!! :)
A project log for Multichannel Audio DSP Field Mixer Recorder
bluetooth app controlled professional portable DSP mixer.balanced audio IO,phantom power,flexible routing,ISO recording. timcode. AVB audio.
