Here's a pic of all 8 preamp cards with 4 balanced line driver card loaded.
The headphone card gets warm , so I'm only running 1.
The protection diodes on the rear of the preamp cards are in the way of the SMD electrolytic caps ( they moving over about 10mm )
They were added to protect the PG2500's against voltage rail error !
The next job is to code the +-5v rail monitoring on the MC and have all the channels immediately shut down if there is a
voltage rail deviation > 0.1V
The would have preferred there protection diodes to be on there too ! next revision I'll move them over 10mn so they are well
clear.
This is all part of learning how to build multi board designs !
The gap between the balanced line drivers and preamps is tight but ok.
you can see the analogue IO panel FPC connector just fits.
I'm thinking of stripping a lot of the 3d printed box away so it's just a frame and then
using aluminium panels to make up the sides and connector panels of the box.
