Just got a rough design drawn up for the 8 channel pre amp with control and Phantom power on/off per channel. Still need to test more with the prototype setup before I print this. Will probably need some changes.
A project log for Multichannel Audio DSP Field Mixer Recorder
bluetooth app controlled professional portable DSP mixer.balanced audio IO,phantom power,flexible routing,ISO recording. timcode. AVB audio.
