Revision 2 files posted
A project log for BooSTick - small AA voltage booster
Switchable 5V and 3.3V power from a AA, using an efficient boost regulator
captmcallisterCaptMcAllister 12/06/2015 at 03:010 Comments
December 5, 2015: I got the rev 1 boards back and they worked, but the maximum current was only about 100 mA. Although I had used the same layout as I had used in a previous project, it really didn't do well at high current. The output voltage would drop. I have corrected the issue by following the layout guidelines in the datasheet to a T. The new files are posted on the project page.
I plan to order some rev 2 boards and try again.
