With the use of the DXJoystick Component from Winsoft XE for Delphi I am able to display the gear in the Compatibility Tool which is a good start. The tool also knows when I shift from a lower gear to a higher and should then send a signal to the Arduino micro and this should send an emulated keystroke to the Racing Game or Simulator you're playing with at the moment.
Leon Bataille
